Author Topic: FiTech install, now engine is knocking, it never ends......  (Read 5478 times)
Offline Katfish
  • 70 Challenger
« on: June 04, 2017 - 08:02:00 PM »
 Is this "rod knock"? I'm just finishing up my FiTech install, and this is what I hear at idle.
I disconnected 1 plug wire at a time to see if I could isolate it, no change at all. Sounded just the same or worse.
The "noise" does go away when the throttle is opened up even a little. Noise only seems to occur at idle.
What are the odds that this happens with the fuel injection conversion?
https://youtu.be/cxK9yT6MpPE
I pulled the inspection cover on the tranny to make sure it wasn't a loose bolt hitting the block.
All 4 TC bolt heads are clean.
Any ideas?
Offline jhaag
Re: FiTech install, now engine is knocking, it never ends......
« Reply #1 on: June 04, 2017 - 09:28:05 PM »
could that be a low speed misfire you are hearing out of the exhaust? maybe lean? rod knock would not go away when raising rpm.  :dunno:
love 70 Challengers
Offline 734406pk
  • Andy
« Reply #2 on: June 04, 2017 - 09:37:47 PM »
Noises like this can be tough to find! My first thought is torque converter to flex plate bolts. I would suggest taking the vee belts off and try to localize where this noise is coming from. It doesn't sound like a rod knock though. What is your hot idle oil pressure?
Offline gyman98
« Reply #3 on: June 05, 2017 - 10:24:17 AM »
Are you using the timing control?  If not do you have it set to tach? What is your A/F ratio when the knock can be heard? Also phone fitech tech support they are very helpful
1970 hemicuda convertible clone 426/727 3.23 8 3/4 suregrip
Offline 1 Wild R/T
« Reply #4 on: June 05, 2017 - 11:08:04 AM »
Has nothing to do with FiTech, have you seen the photos?  Put a flex plate on it period....
Offline cudabob496
« Reply #5 on: June 05, 2017 - 01:18:25 PM »
something under distributor cap?
2011 Kawasaki Z1000
« Reply #6 on: June 05, 2017 - 06:46:40 PM »
What about the fuel pump pushrod , did you remove that
Offline 734406pk
  • Andy
« Reply #7 on: June 06, 2017 - 08:33:37 PM »
The more I listen to the Youtube video, the more it sounds like the torque converter is loose/rattling on the flex plate.  :dunno:
Offline Deadeye74X2
« Reply #8 on: June 06, 2017 - 08:40:28 PM »
Blown exhaust manifold gasket?? Do you hear it on the other side as well??
« Reply #9 on: June 06, 2017 - 10:27:33 PM »
 :clueless:  Doesn't sound like rod knock to me? First thoughts were exhaust pipe rattling on something, broken or loose motor mount?
Offline 7212Mopar
« Reply #10 on: June 07, 2017 - 01:05:54 AM »
 I vote for broken motor mount.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline cudabob496
« Reply #11 on: June 07, 2017 - 02:41:55 AM »
something loose under a valve cover?
2011 Kawasaki Z1000
Offline Katfish
  • 70 Challenger
« Reply #12 on: June 13, 2017 - 09:37:48 PM »
Those who said torque converter bolts were right, they had come loose and where letting the TC slap around on the flex plate.
Seems weird that all 4 would come loose.
Offline 734406pk
  • Andy
« Reply #13 on: June 13, 2017 - 10:10:09 PM »
Glad it was something simple! Maybe put some 242 Loctite on them and re-torque.
Offline jhaag
« Reply #14 on: June 13, 2017 - 10:39:30 PM »
Hmmm...original post said those bolts were checked and ok? Oh well glad you figured it out!  :thumbsup:
love 70 Challengers
