Author Topic: FiTech install, now engine is knocking, it never ends......  (Read 5474 times)
Offline cudabob496
Re: FiTech install, now engine is knocking, it never ends......
« Reply #15 on: June 14, 2017 - 01:21:53 AM »
Those who said torque converter bolts were right, they had come loose and where letting the TC slap around on the flex plate.
Seems weird that all 4 would come loose.
came loose because not torqued properly?  May need new bolts?
2011 Kawasaki Z1000
Offline TelisSE440
« Reply #16 on: June 14, 2017 - 04:23:55 AM »
Glad you found out early.  :thumbsup:
Offline cudabob496
« Reply #17 on: June 14, 2017 - 03:33:42 PM »
but how does FI loosen torque converter bolts???
that is the question!
2011 Kawasaki Z1000
Offline 73_Cuda_4_Me
« Reply #18 on: June 14, 2017 - 05:33:27 PM »
 :clueless:
Must be too much pre-load on the muffler bearings after FI installation, or worst case scenario - a loose framowitz knudsen valve popping off!!!
 :roflsmiley:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline cudabob496
« Reply #19 on: June 14, 2017 - 06:18:04 PM »
that's what I was thinking
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #20 on: June 14, 2017 - 09:20:07 PM »
Just a guess here but i think the converter bolts were loose to begin with. The FiTech didn't "self tune" yet so the idle was a little rough making the converter rattle at idle. Again, just a guessing.  :clueless:
Offline Katfish
  • 70 Challenger
« Reply #21 on: June 14, 2017 - 10:07:02 PM »
I'm guessing it was just a bad coincidence, car's been down for at least 2 months while I worked on and off on the fuel injection conversion.
I finally get it to the point of being able to try it out, and that was what I heard.  No issues before I started the FiTech install.
Offline cudabob496
« Reply #22 on: June 15, 2017 - 12:17:35 AM »
aren't those bolts supposed to be replaced on occassion?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #23 on: June 15, 2017 - 09:02:30 PM »
You can replace them with ARP bolts or use Loctite. Loose converter bolts are a common problem on all makes.
Offline 69bcuda
« Reply #24 on: June 16, 2017 - 11:57:38 AM »
IMO, Loose TC bolts can also damage the threads of the bosses and degrade retention. New bolts, clean threads of all oil, Loctite and torque. Wait for the Loctite to setup after your install.
Offline cudabob496
« Reply #25 on: June 18, 2017 - 01:24:10 AM »
Also, I had leaking valve covers.  Finally noticed the threads on the valve cover bolts were about gone!
If a bolt comes lose, most likely the installer messed up somehow.
2011 Kawasaki Z1000
