Author Topic: are these the correct numbers for the six pack carbs on a '70 Cuda w/ auto trans  (Read 1163 times)
Offline gb70
Carbs: Front: H-14 3389 also found numbers on
top of carb: D1565
list 4671
6R3406R
Center: 3039
D1565
list 4375
6R3589R
Rear: H-14 3389
D1565
list 4672
6R3406R
« Last Edit: July 03, 2005 - 08:46:41 PM by gb70 »
I don`t have a reference for the #s but the outboards look right , the center carb changed with different applications
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
Hi CP .... I have a local guy that has a set of Direct Connection over the counter Six Pack set up.   He claims that the front and rear carbs have no numbers with the exception of the following from him:
"the only numbers i can see is by the top is has d 1565 and under that is 6r3040b and on the base 12r3646b  but no list number like the centre carb".   Centre carb has the correct numbering.
Is it possible that the Direct Connection stuff may not have been labelled other than the above?
Thanks .... Gary
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
the list # is stamped on the rear of the body on the end carbs , there is no choke boss to stamp on the front of the housing
