Author Topic: Replaced previous aftermarket stereo. New stereo doing the same thing.  (Read 1542 times)
Offline Chris Pauluk
  • New to the E game
So the stereo that came in my car (Pioneer CD player) didn't work very well when the car was running, worked fine when the engine was off.
When running, scratchy sound as if a bad connection.
New Alpine stereo installed.
Same situation.
All speakers have been replaced with aftermarket as well as all new wiring.
What am I doing wrong?
Sent from my SGH-M919 using Tapatalk
Chris Pauluk
Eagan Minnesota
1973 Plymouth Cuda 340 4spd (70 AAR clone'ish) bought it that way..
Offline challenger4404spd
probably need to change your ignition wires.
found it interesting that a cheap handheld AM radio can help track down the source ..  Poor ground at antenna/body was an issue I've dealt with
http://www.popularmechanics.com/cars/how-to/a84/1272491/
  • New to the E game
MSD Super Conductor 8.5mm
Chris Pauluk
Eagan Minnesota
  • New to the E game
Would that matter if I was playing a CD?
Chris Pauluk
Eagan Minnesota
Just proves the RFI noise is coming through the electrical system & not over the air.
Does this happen only when playing CDs?
« Last Edit: June 06, 2017 - 08:40:13 PM by Bullitt- »
  • New to the E game
Hmmm.   Anyone ever figure out a way to make it right?
Chris Pauluk
Eagan Minnesota
There's no one magic fix... I'm seeing on Youtube a lot of people running amps that have ground issues but you have not specified any equipment other than aftermarket head unit with CD player & speakers.
Does this only happen when playing CD's?  Does the noise change with engine RPM?
The factory used a noise suppressor in the distributor(I see some external on the coil), is that in place?
There are all kinds of noise filters on the market. The best they have ever done for me is lower the volume of the noise.  Finding the source & eliminating or isolating is the best solution.
  • New to the E game
For now it's just the head unit with all new speaker wiring and aftermarket speakers in the stock locations.
I haven't even thought about amps.
I'll need to upgrade the charging system.
Chris Pauluk
Eagan Minnesota
  • New to the E game
Also.   The coil is aftermarket.
I'm not sure what the noise filter looks like.
Chris Pauluk
Eagan Minnesota
