Author Topic: Sealing the Rear Window  (Read 1510 times)
Offline money pit
« on: June 09, 2017 - 10:56:49 AM »
I have a 70 Barracuda that has a rusted out trunk pan. While researching the source of the leak, I found 3/4 of an inch of silicon sealer all around the rear window. There was so much sealer, the moulding was stuck to the sealer. Do I need to remove the rear window to properly real it? Thanks
Re: Sealing the Rear Window
« Reply #1 on: June 09, 2017 - 12:03:00 PM »
I would.  Get all that crap out of there. Clean up the window channel and start fresh. :2cents:
Push a piano wire through the sealant and saw back and forth...all the way around the glass.  Hopefully you can get it out easily.
Offline money pit
« Reply #2 on: June 09, 2017 - 09:32:38 PM »
There is so much silicon sealer, it's taking forever to remove it. As I thought there were two wholes near the bottom of the window on each side that rusted through. Any ideas on how to prevent this?  I had the same problem with my Challenger. Thanks
Offline brasil
« Reply #3 on: June 10, 2017 - 04:30:49 AM »
...first of all you have to remove the window...  then you clean the frame...
and now it comes..  IF you have some time and the possibilities    I would create a DRAIN HOSE in the "middle " most downward point of the frame
HOW do do this ?   You simply drill  a hole in the windowframe.. and then you need to weld in a "fitting" that sits  flush with the frame..  on the fitting you ll put a clear rubber /plastic hose... and route him to the left  or right...and then downwards...  through the trunksfloor
This should prevent the frame from rotting in the future
Greetings Juergen
Offline money pit
« Reply #4 on: June 11, 2017 - 01:23:15 PM »
 Thanks good info
Offline chargerdon
« Reply #5 on: June 21, 2017 - 10:56:29 AM »
HMMMMM   I have a 74 challenger that i bought WITHOUT a rear window anf front windshield.    It also had a rusted out trunk floor and rusted spots in the trunk fill strip down to the trunk lid.   So, obviously the window that was in there was leaking...and for a long time.
Now, that being said, I simply repaired all of the rust and made sure that the entire channel for the rear glass fit the glass with no large gaps and that the front windshield channel was in great shape.
Then I had the entire car painted.
Then i bought a used rear window and took it to a auto glass shop for installation (also had them obtain and install the front windshield as new ones are readily available for reasonable prices).    My cost for this was $100 + $20 shipping for the used rear window, and $275 to the auto glass show for the front windshield and professional urethane installation of both.    So just under $400.
I have no leaks!!!   Have checked many times when washing the car, and when caught in a flash rainstorm at a local car show.  I would believe that today's urethane sealers, and trained installers are so much better than what was used back in the early 70's in the factory that it isn't even funny.   Remember into the late 60's they still were using gaskets for the front and rear windows, so, the urethane sealers were of early design but in the early 70's.  Also, i don't believe that they gave the installers at the factory enough time to do the job properly.
Incidentally, the front windshield the auto glass shop supplied, turned out to be a "little thinner" than the original OEM glass.   So to get it to properly come up to the level of the roof and surrounding area, they had to put in a "bridge".   I.e first they put in a layer of urethane and let the car sit in their shop overnight to "set up".   Then they put fresh urethane and the glass in.   They said this is very common on the older classic cars.   It now fits perfectly and no leaks!!
In other words have it properly prepped and installed with good urethane and activators on the glass, and there shouldn't be any issues..
Just my two cents worth!!
