Author Topic: Different set of heads on a 440?  (Read 1106 times)
Offline TelisSE440
« on: June 17, 2017 - 10:28:45 AM »
Hi, in an older post ( http://www.cuda-challenger.com/cc/index.php?topic=118521.60 ) about a leaking 440, i discovered that my driver's side cast 906 head was cracked. Anyway i bought a used set of 906 heads and just i was finishing the cleaning job on the replacement head, i discovered that my cracked and replacement heads are different, my cracked head was ported and my new one is stock. My question is this, can i install it and get it done with, or i will have to port the replacement one? Is it a matter of doing damage or just low performance result? (which i don't care)
Offline jhaag
Re: Different set of heads on a 440?
« Reply #1 on: June 17, 2017 - 11:01:17 AM »
won't matter except for performance. Only issue might be if old heads were decked, you could end up with manifold alignment issues.
« Last Edit: June 17, 2017 - 11:04:29 AM by jhaag »
love 70 Challengers
Offline cudabob496
« Reply #2 on: June 17, 2017 - 05:12:46 PM »
why not do a little bowl cleanup on the stock head?
porting seems fairly easy, if done right. Lots of You-tube
videos on it
2011 Kawasaki Z1000
Offline TelisSE440
« Reply #3 on: June 17, 2017 - 07:40:32 PM »
Unfortunately, i don't have the tools and i've moved far away from my budget with this head crack. Would like to do it a lot, but can't afford it now...
