Author Topic: front end sag  (Read 1178 times)
Offline Dgoode87
front end sag
« on: June 19, 2017 - 03:19:19 PM »
hey guys I just finished installing the hotchkis suspension kit and I set my torsion bars to my ride height but when I can back I noticed the car sagged about an inch and a half. could my torsion bars be wore out or is this something else. I raised the front end again in hope that it just need to sit for a bit  with everything being new.  the bars are what was on the car when I bought it.
Thanks
Offline GoodysGotaCuda
Re: front end sag
« Reply #1 on: June 19, 2017 - 03:28:32 PM »
Are the bars new/Hotchkis or "old"?
What parts did you install?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Dgoode87
Re: front end sag
« Reply #2 on: June 19, 2017 - 03:36:44 PM »
The torsion bars are old. I put on new upper control arm new sway bar new strut rod and new tie rods
Re: front end sag
« Reply #3 on: June 19, 2017 - 04:08:47 PM »
After you put the car back on the ground, did you bounce the front end or not?  You need to adjust the torsion bars with the wheels off the ground.  Lower the car back onto its wheels and bounce the front end.  Then check your heights.  Also, I hope you loosened the LCA pivot pin nuts before adjusting the ride height.  If not, loosen them now.  Only tighten those nuts AFTER the ride height is set.
Offline Dgoode87
Re: front end sag
« Reply #4 on: June 19, 2017 - 04:58:31 PM »
I did not bounce the car i will try that tonight thanks
Offline Dgoode87
Re: front end sag
« Reply #5 on: June 20, 2017 - 09:12:00 AM »
Thanks burdar that seemed to work
