Author Topic: Exhaust Kit - 'Cuda Only - Recommendations other than TTI?  (Read 2440 times)
Offline GoodysGotaCuda
« on: June 26, 2017 - 12:35:44 AM »
I am in need of header-back exhaust and 'Cuda tips to exit the rear valance. I have not been able to find a kit online that is intended to exit through the valance, only turn downs.
Are there other options outside of TTI for a kit like this? $1,100 is quite steep and I have too much scar tissue to trust taking it to an exhaust shop.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 1 Wild R/T
Re: Exhaust Kit - 'Cuda Only - Recommendations other than TTI?
« Reply #1 on: June 26, 2017 - 02:32:10 AM »
You'll probably get a good recommendation but on the exhaust shop side if you ask around to local hotrodders there is probably a good shop around... We have a number of hack shops but we have two local shops that do excellent custom work....
Offline PLUM72
« Reply #3 on: June 28, 2017 - 12:18:39 PM »
You have alot of custom stuff going on with your car.  A standard TTI kit or kit from any manufacturer may not work without significant tweaks.  You might need to buy a mandrel bent pipe kit and weld it up yourself.  The other option is a combination of all the above.  Use TTI or Accurate Exhaust or what ever manufacturer for the back part, say tips back to mufflers then fabricate your own head pipes.
« Reply #4 on: June 28, 2017 - 12:57:29 PM »
I bought a TTI setup. I have TTI headers and engine mounts, they confirmed that the t56 shouldn't be an issue. After that, it's all "factory" back there.
1976 Dodge Warlock
