Odd 426 crate Hemi problem, no heat
Author Topic: Odd 426 crate Hemi problem, no heat  (Read 5544 times)
Offline 734406pk
  • Andy
Re: Odd 426 crate Hemi problem, no heat
« Reply #15 on: July 02, 2017 - 02:49:35 PM »
Yeah, but with a 180 thermostat the fan can be blowing all the air it wants, the engine should warm up to 180..... I'd try another thermostat....  :2cents:
This is true! The engine temp should be regulated by the thermostat. The t-stat should open and close based on its set point, regulating coolant temp to 180 deg in this case. This could be a far fetched idea; but the engine also radiates heat to the atmosphere from it's own surface area, independent from the liquid cooling system. Air flow from a stuck thermo clutch increases the heat rejection to atmosphere to some point, possibly lowering the coolant temp at light load below the thermostat opening set point. I have had this happen on a few vehicles, but they were definitely not Hemi Cudas. Just a crazy idea in the process of elimination. :thinkerg:
Offline gyman98
« Reply #16 on: July 02, 2017 - 04:16:42 PM »
I agree,  might be a defective thermostat.  It was a Stant but I suppose even they have QC issues
Yes seems unlikely but a cheap,  quick test anyway
The clutch fan spins free with the engine off but I don't know how to test it other then that
1970 hemicuda convertible clone 426/727 3.23 8 3/4 suregrip
Offline 734406pk
  • Andy
« Reply #17 on: July 02, 2017 - 05:15:04 PM »
"Yes seems unlikely but a cheap,  quick test anyway"
Offline 73440
« Reply #18 on: July 02, 2017 - 05:20:10 PM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 734406pk
  • Andy
« Reply #19 on: July 02, 2017 - 06:00:50 PM »
Testing a fan clutch , https://itstillruns.com/test-fan-clutch-5086903.html
Good article! I tested my OEM fan clutch the same way (440 6 Pack) and found that it was too loose. Changed it out with the Hayden replacement, which felt right but made no difference. 203-205  degrees  all the time, with either fan clutch. It never overheats but that temp makes me nervous...
Offline gyman98
« Reply #20 on: July 02, 2017 - 11:48:14 PM »
Thanks for the article,  I'll try it tomorrow
Offline cudabob496
« Reply #21 on: July 06, 2017 - 08:27:22 PM »
with alum heads, there is an ideal eng temp for max power, but dont recall what it is. Maybe around 200?
2011 Kawasaki Z1000
« Reply #22 on: July 06, 2017 - 08:55:47 PM »
Wow wish I had your problems!  :grinyes:  I'd say as others have too, that your thermostat is not functioning properly!
Offline 734406pk
  • Andy
« Reply #23 on: July 07, 2017 - 09:17:35 PM »
195-200 deg sounds good to me in this case. The engine runs nice and smooth in that temp range. 6 packs seem to like the extra heat.
Offline gyman98
« Reply #24 on: July 08, 2017 - 11:42:07 AM »
  I know right,  so weird.  Going to have to try another thermostat
I will likely stick with a 180° as that's what mopar recommends in their crate hemis
Offline gyman98
« Reply #25 on: July 22, 2017 - 01:23:12 PM »
Well tried another 180° thermostat still only getting a Max of 160° On the highway
