Author Topic: Rear Brake Lines 70 Cuda  (Read 1016 times)
Offline DirksCuda
« on: July 03, 2017 - 10:44:02 AM »
I bought a set of prebent brake lines from Mancni Raccing for a 70 Cuda 11 in drums. I'm trying to put the back lines on before installing the rearend in the car. This cuda was torn down in 2002. Is there a bracket that the brass block bolts to, the lines seem to end up around the rear axle vent tube. anyone got a pic of there rearend with the lines hooked up thanks for any help
Re: Rear Brake Lines 70 Cuda
« Reply #1 on: July 03, 2017 - 11:38:53 AM »
The axle vent bolt is what holds the brass block onto the housing.
This is the correct bolt to attach the block.
http://www.brewersperformance.com/prodimages/large/V798-1.jpg
« Last Edit: July 03, 2017 - 11:43:58 AM by burdar »
Offline DirksCuda
« Reply #2 on: July 03, 2017 - 01:57:11 PM »
Thanks burdar that's what I needed. This is my first Mopar and the car was stripped about 12 years ago. Nothing was tagged or marked so I will be asking a lot of question Thanks again
