Author Topic: what to use to clean blue coating off new polyglas tires  (Read 2015 times)
Offline culp71
« on: July 06, 2017 - 12:14:24 PM »
I received my new polyglas E60's tires and they are beautiful!!
however they have that blue film all over them....what is the best thing to use and procure to remove the blue coating that is all over the tire and white lettering, with out damaging or removing the white lettering?
« Last Edit: July 06, 2017 - 12:18:13 PM by culp71 »
Offline bc3j
« Reply #1 on: July 06, 2017 - 12:38:06 PM »
I'm sure there are a lot of methods, but I've always used comet cleanser and a scrub brush. Been using that method since the 80's when I had white wall tires. Flush it with water. Always worked for me. I tried using some wet/dry 800 grit sandpaper soaked in water and that'll clean off the rwl also. Worked ok but I prefer the comet cleanser routine. Also used Mequirers hot shine foam tire cleaner and that also cleaned the rwl and the sidewalks. Just have to careful about what you use that won't damage the finish on the rims. I admit to being a creature of habit and I'd been interested in what the other guys here have to say about it.
« Last Edit: July 06, 2017 - 12:41:43 PM by bc3j »
Re: what to use to clean blue coating off new polyglas tires
« Reply #2 on: July 06, 2017 - 12:46:32 PM »
Westley's Bleche White has always worked great for me.  I even used it to clean up some original rubber parts that I was going to reuse.  It takes off YEARS of road grime and cleans whitewalls/white lettering really easily.  Black Magic recently bought the product and has their name on it now.  Some people have complained that the formula has changed.
It takes my breath away whenever I use it.  You might want to use a mask if using it indoors.  :2cents:
Offline jim.k
« Reply #3 on: July 06, 2017 - 06:30:56 PM »
x2
Offline 76orangewagon
« Reply #4 on: July 07, 2017 - 08:20:34 AM »
X2 on the Wesley's. I use some Clorox scouring powder and a good stiff brush, it comes right off.
Offline Aracer
« Reply #5 on: July 09, 2017 - 03:43:56 AM »
Man,,, I must be old; I was told, as a child, not to worry, since the blue film is water soluble like soap.  Just wash with car wash and a white wall brush (toilet brush from the 1950's) and rinse until white. Ajax and similar powders are going to leave the tire and wheel, worse off. They did not invent ArmorAll until the 70's.
Offline chargerdon
« Reply #6 on: July 11, 2017 - 04:15:12 PM »
Westleys Bleach White works great and harms nothing.
Offline smallhurst
« Reply #7 on: July 13, 2017 - 04:01:28 PM »
It is still a water soluble coating.. warm water and a stiff brush is all that is necessary to get the Blue off..  keeping them white, use SOS or Brillo pads.
Offline culp71
« Reply #8 on: July 13, 2017 - 04:27:18 PM »
thanks for all the input, actually used a dish rag and a little warm water with few drops of dish washing soap and it all wiped right off and the white is bright and clean :thumbsup:
