After Market Car Stereo
Author Topic: After Market Car Stereo  (Read 1021 times)
Offline 7212Mopar
« on: July 06, 2017 - 03:52:09 PM »
My car is a 73 Challenger. I pulled and will be saving my stock AM/FM radio and replacing it with an aftermarket CD player. The player will drive two 6x9 two way at the back and two 1" tweeter at the front dash, no external amp. The unit is rated 25 watts only. I plan to run the switched power and connect to the original radio power connector (red and black wires I think). The battery wire that powers the clock of the player will be connect to the spare connection tagged "battery" at the fuse block. Anyone had done this see any problem of what I am doing? Is there a better way to do this?
Other wiring modifications I plan to do is join the black and red wires at the amp gauge together to bypass the amp gauge. I already have a volt meter. Later will also install the headlight kit from Crackedback that draw from the battery with relays. The back and red wires at the wire connector joining the steering column and the dash wiring harness were burned and previous owner crimped the wires together and bypassed the connector. I will be cutting wires if I need to pull the steering column in the future.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Re: After Market Car Stereo
« Reply #1 on: July 06, 2017 - 06:45:49 PM »
Radio connections will work fine however I found the wire to the fuse block battery terminal a bit awkward(sticks out so you can see it) so I found another hot connection in the wring harness to tap.
Offline gyman98
« Reply #2 on: July 06, 2017 - 08:18:14 PM »
You can get 90° female spade terminal connections that should help with that problem
1970 hemicuda convertible clone 426/727 3.23 8 3/4 suregrip
