Author Topic: 17x8 Year One Rallyes - not enough stud thread to fit  (Read 2142 times)
Offline MopSquad
« on: July 11, 2017 - 12:25:47 PM »
Hello all!   Tried installing the new 17x8 rallyes on my '70 Cuda vert.  The new 17x8 rally's wheel is quite thicker at the hub than my stock 15x7 Rallye wheels.  Hence more of the stud is used up sitting flush. Here's a pick of my front brake rotor/hub.  Does this look normal? The stud protrudes .75"
Offline 340-FOUR- BARRELL
Re: 17x8 Year One Rallyes - not enough stud thread to fit
« Reply #1 on: July 11, 2017 - 02:11:34 PM »
Rule of thumb is the lug nut needs to make at least seven complete revolutions to safely secure the wheel. Best solution if the stud is too short is to have longer studs press in. With the 17" wheels on, how many revolutions of the lug nut is able to grip the stud?
Offline 1 Wild R/T
« Reply #2 on: July 11, 2017 - 02:15:58 PM »
Those don't look like the right studs... Thats an original 70 two piece rotor they take long shouldered studs....
http://www.rockauto.com/en/moreinfo.php?pk=1060287&cc=1078444&jsn=567
How are the studs in the rear?
« Last Edit: July 11, 2017 - 02:21:03 PM by 1 Wild R/T »
Offline MopSquad
« Reply #3 on: July 11, 2017 - 03:31:53 PM »
Maybe one or two, even if it catches at all.
Offline MopSquad
« Reply #4 on: July 11, 2017 - 03:33:05 PM »
Thanks for the info.  Easiest would to press in longer studs.  I haven't checked the rear yet, but I will tonight.
Offline burdar
« Reply #5 on: July 11, 2017 - 04:31:56 PM »
Those studs look short.
Offline MopSquad
« Reply #6 on: July 12, 2017 - 12:53:20 AM »
Good news. The rear studs are long enough.  Have to purchase some 7/8 hex lugs. The stock 3/4 hex are not enough hex diameter to safely secure the 17x8 wheels
Offline 1 Wild R/T
« Reply #7 on: July 12, 2017 - 12:43:20 PM »
Pull off a rotor, knock a stud out & measure it.... Probably around 1.25" long, the correct stud will be a 1 7/8....
Offline MopSquad
« Reply #8 on: July 12, 2017 - 07:44:53 PM »
Thx! Do the new studs need to be pressed in with an Hyd-press?
Offline 1 Wild R/T
« Reply #9 on: July 12, 2017 - 10:36:37 PM »
It is the preferred method but plenty have been drawn in with the lug nut.... Personally I don't like stressing the lugs that hard.....
Offline MopSquad
« Reply #10 on: July 13, 2017 - 04:05:46 PM »
Thx,
Yes, I've used that method before.
Offline GoodysGotaCuda
« Reply #11 on: July 13, 2017 - 04:28:38 PM »
3/4" are more than adequate.
I used them on my Wrangler that had 135lb wheel/tire assemblies.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline MopSquad
« Reply #12 on: July 13, 2017 - 06:53:20 PM »
Yeah, thinking that too.  Year One suggested 7/8 with a 2.5" length.  I think that may be more useful for the '72+ Rallye center cap.
