Author Topic: Need advice with Sublime color issue  (Read 1374 times)
« on: July 11, 2017 - 11:40:09 PM »
As the title says, I need some guidance, advice, etc on an issue I am experiencing with the paint on my Cuda. I painted this car last summer and have yet to assemble it. I worked hard to get it painted and went through a lot of trials and tribulations. Suffice to say I got it done, then somewhere along the way I had an issue when a piece of metal I was grinding skipped across the right rear quarter leaving 3 nicks. A few weeks ago I set about fixing the damage and got it leaved out, scuffed up and then went on to spray it. Upon cutting and buffing I noticed a line on the sail panel, I wet sanded it and buffed it repeatedly and eventually got to the point in the picture which is there is a transition where the paint is lighter (first paint job) and darker (repaired area).
So after a lot of thought I have reached the conclusion that I am probably going to have to reshoot the car to get it evened out but before I do I wanted to come here and get some more opinions. So the "ask" here is this;
1. is there anyway to fix (without respraying the whole car) what I have going on now, if so what?
2. if there isn't anyway to fix it and I have to respray it;
   a. can I scuff the existing paint and shoot over it? (I am not concerned about the final color, only that it is uniform)
   b. do I need to reprime the car before respraying it?
While this sucks, the car is still essentially "ready for paint" in that it is not assembled. I do have the AAR blackout on it which I will have to mask but other than that, I just need to mask the car and go.
I appreciate any relevant assistance/advice given
Offline plumcrazzy
Re: Need advice with Sublime color issue
« Reply #1 on: July 12, 2017 - 09:34:35 PM »
No need to reprime.
You can try blending the paint a little by flowing lighter and lighter coats further and further away from the original coats.
If you decide to recoat for uniformity make sure you scuff to a dull finish all over and use the same type topcoat that the car has now and I would suggest using the same brand as well for compatability.
Just my thoughts from experience---easier to say than accomplish though.
Good luck.
« Reply #2 on: July 12, 2017 - 11:48:03 PM »
Appreciate the input. I will be using the same brand and type of paint. I think I am better off just to reshoot the entire car rather than try and blend in just that area.
Offline larry4406
« Reply #3 on: July 14, 2017 - 07:56:32 PM »
No expert here but any chance it is related to the quarter to roof seam?
I've read that painted roof cars had leaded seams and vinyl top cars had "bondo" seams.  I have read that welding a patch over the seam can result in telegraph of the seam thru the finished paint.  Not sure how yours was finished.
« Reply #4 on: July 15, 2017 - 12:48:41 AM »
It absolutely has nothing to do with that, the quarter seam is completely welded, filled and then a little body filler over the top (no lead at all). I know what caused it, just am not sure if it could be corrected. I have resigned myself to repainting the entire car (except the black out areas).
