"When you mounted the tires did you fill load the air to at 45 lbs to seat the tires.
The bias tires are terrible on the road."
I did what ever they said, I know it had a strict call out on each tire stating not to exceed a certain psi when seating the bead.
So I followed it, and the beads all seated properly, with no issues...
I actually prefer bias tires, I have them on all my other classics, as all the suspension back then were designed with these tires originally, I prefer to run them on any older stock suspension, just never have used polyglas in particular before.
