ya, some input from someone who has done this would really help all of us who are waiting to do this, particularly
1. th vinyl has a white paper-ish film over the outer surface, do I want to remove this when I install the graphic or after?
("googled" and seen the GYC guy do it that was on a 71 cuda billboard graphic)
some say to leave it and install, because the vinyl is easy to scratch or stretch if this film is removed
but then others say remove this film then install, otherwise you cant see really what your doing plus if there are any imperfections in the vinyl installation until its too late then have to resolve to pin holes to relieve etc.
2.do I have to heat vinyl to get it to fit tightly in tapered holes for door handle and turn indicator?
I have not found anything really pointing out these step in particular, I did see where Rick's billboard instructions pointed out the use of a heat gun for the door jam area, so wonder if the same is needed for these holes?
3. do I do these holes at same time as main body of vinyl or later, and do I "re-wet" certain edges with or without heat or do these parts "dry"?
