Author Topic: cuda billboard vinyl location...location?  (Read 3445 times)
Offline culp71
Re: cuda billboard vinyl location...location?
« Reply #15 on: August 10, 2017 - 08:40:25 AM »
alright, with a little luck and some trial and error I was able to tackle the door sections of the billboards. while never finding any actual specific information that detailed the different steps needed for this graphic, (that would differ from any other normal vinyl installation)  I worked through them, they are on, perfectly located, and look flawless!!
thinking I had it figured out I proceeded to the rear quarter section, expecting it to be easer because only 1 marker hole to contend with. unfortunately I am stuck again.
so the issue is the rear section below the marker has to be relief cut, then over lapped over the lower section of the vinyl, this is a problem because the premask, I have been told by many and phoenix graphixs that the premask has to be left on until vinyl is installed and dried for at least 3 hours... if this is so how does one overlap it, does one remove the premask in this overlap section, and or leave the backing on until the rest is on and dried, then come back later and complete the overlap part?? or do I "pac-man" relief cut a wedge out of the graphic itself removing both backing and premask for that section?
because of this I was not able to install the rear quarter section graphics... :(
 :pullinghair:
« Last Edit: August 10, 2017 - 12:47:54 PM by culp71 »
Offline culp71
« Reply #16 on: August 15, 2017 - 08:55:15 AM »
some insight from anyone who has done this would be priceless. :1zhelp:
Offline phoenixgraphix
« Reply #17 on: August 18, 2017 - 04:32:42 PM »
https://www.youtube.com/watch?v=s5WJdK7fH7E
Hope this may help you. Mark Worman installing cuda stripes with tips for installation.
Offline culp71
« Reply #18 on: August 21, 2017 - 10:35:37 AM »
thanks, but that's no help as I watched that a ton about 1 year ago, and it just conveniently skips right over all the details/questions I have...
« Last Edit: August 21, 2017 - 03:17:40 PM by culp71 »
