Author Topic: 472 Hemi question  (Read 872 times)
Offline dana60
472 Hemi question
« on: July 21, 2017 - 11:24:24 PM »
I bought a 472 Hemi for my 70 CUDA. I heard it will be very difficult to start after you turn it off after driving it  ( being that it's hot ) ? Is there a fix for this ? Fuel injection ? Or ....????? Thx
 :wavingflag:
Offline cudabob496
Re: 472 Hemi question
« Reply #1 on: July 22, 2017 - 01:34:02 AM »
there is an easy fix for any hot engine that has trouble starting.
usually involves a heat shield on the carb, and phenolic spacer,
and insulation on the fuel lines. Search this site for a lot of discussion
on the issue. Good luck!
2011 Kawasaki Z1000
Offline cudabob496
« Reply #2 on: July 22, 2017 - 03:42:45 AM »
also, engine needs to be in tune, with carb properly adjusted,
and correct timing. Engine must be well grounded.
« Last Edit: July 22, 2017 - 04:11:52 PM by cudabob496 »
2011 Kawasaki Z1000
