I feel so noobish.
Author Topic: I feel so noobish.  (Read 2951 times)
Offline BlueStreak_Johnnie
  • Y helo thar from Sunny South TX
I feel so noobish.
« on: July 05, 2005 - 10:59:28 PM »
Where/what is the best place to attach the cherry picker?  Can't use a plate, my intake manifold is only held on with 2 bolts.  Can i use the intake manifold bolt holes to attach to?
J.
« Last Edit: July 14, 2005 - 01:56:09 AM by Blue_Bucket »
Offline Killer_Mopar
Re: I feel so noobish.
« Reply #1 on: July 05, 2005 - 11:11:46 PM »
You can attach the picker to the bolt holes for the intake, but remember to put the bolts all the way on. I usually use the bolt holes that are not used, but I have used the intake bolt holes. If you dont have one, you might want to buy an engine leveler with chains because it will make the job much easier.....
« Reply #2 on: July 05, 2005 - 11:20:42 PM »
Cool thanks.  Yeah i bought a hoist and leveler combo over the weekend.  I haven't had a chance to set it up yet, gotta convince the wife to park her car outside for a few days. :mad:
J.
« Reply #3 on: July 05, 2005 - 11:37:08 PM »
Just don't let anybody try and convince you ever that you need a "sky hitch" or an O ring installer.  :laughing:
dodgetkboy78
« Reply #4 on: July 06, 2005 - 02:25:33 AM »
I use the accessory bolts in the front and back of the head. :thumbs:
Engine leveler??????? :eeksmall:
aint that long waterpump bolt you poke thrue the chain under the hook? :???: :beer: :thumbs:
Offline GoodysGotaCuda
« Reply #5 on: July 10, 2005 - 11:30:16 PM »
Intake, Accessory on the heads, or head bolts (heads off). Id NEVER lift a motor by the intake where the carb mounts  :spank:
1976 Dodge Warlock
Wheel & Tire Specs:Link
dodgetkboy78
« Reply #6 on: July 11, 2005 - 01:23:48 AM »
why is that? A lot of people do it. (I dont, but still)
Offline Wrencher
  • 73 Plain Jane 318 Auto Project
« Reply #7 on: July 11, 2005 - 10:43:22 AM »
It's just the tought of those little bolts holding the entire weight of the engine.  I guess I would consider using the carb bolt holes IF I had a plate to fit the intake with the 4 correct bolts but I've always used either the corner intake bolts or bolts on the end of the head.
« Reply #8 on: July 13, 2005 - 09:30:07 AM »
 :iagree: Just dont like the fact of those lil bolts holding into aluminum and holding up an entire motor  :ack:
1976 Dodge Warlock
Offline Wrencher
« Reply #9 on: July 13, 2005 - 10:59:39 AM »
It's just psychological l I guess.  If the engine weighs 500 lbs, then each bolt only holds 125 lbs.  Not that much.
Offline hotrod98
    • Maniac Musclecars
« Reply #10 on: July 13, 2005 - 11:27:57 AM »
My 426 crate hemi weighs 800+ lbs and it was loaded into the crate by the plate bolted to the aluminum intake. It will hold.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
« Reply #11 on: July 13, 2005 - 11:45:09 AM »
Well there's proof enough...Just would be my luck that it wouldnt hold, especially with a $10,000+motor going right over the middle of a car thats worth a $10,000 motor  :dogpile:
1976 Dodge Warlock
Offline gomangoRT/SE
« Reply #12 on: July 13, 2005 - 02:52:39 PM »
Absolutely..........attach to the accessory holes in the front and rear of the heads........dont!!!! attach to the holes where the intake manifold bolts to the head.......no no no no no.........
« Reply #13 on: July 13, 2005 - 03:47:30 PM »
Now, i had heard that before.  Why not use the intake manifold bolt holes?   :dontknow:
J.
Goody i Love that panoramic!
« Last Edit: July 13, 2005 - 03:56:29 PM by Blue_Bucket »
« Reply #14 on: July 13, 2005 - 05:12:20 PM »
[thread_hijack]
Thanks! Everone takes pics of their car just in the driveway or somethin, i like takin it out somewhere  :
guitar:
[/thread_hijack]  ;D
1976 Dodge Warlock
