I feel so noobish.
Author Topic: I feel so noobish.  (Read 2950 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
Re: I feel so noobish.
« Reply #15 on: July 13, 2005 - 07:27:15 PM »
if it was me id use the bolts in the heads method!! when i pulled my 360 out of the charger i use a lond bolt into the drivers side head and the bracket that holds the tanny to the engine bolt hole on the pass side!!
My family, My cars, My guns three things il fight for!!
Offline BlueStreak_Johnnie
  • Y helo thar from Sunny South TX
« Reply #16 on: July 13, 2005 - 08:02:17 PM »
Absolutely..........attach to the accessory holes in the front and rear of the heads........dont!!!! attach to the holes where the intake manifold bolts to the head.......no no no no no.........
I'm just curious for an explanation as to "Why Not?".  The Intake holes are 3 inches away from the accessory holes, and there both on the head. Only thing i can think of is breaking a bolt off in one of those holes, that would suck. But hey you could break a bolt off in the water jacket, the accessory  hole( populated with a bracket), tranny mount.... etc. etc..
J.
Offline Mr. 6pak2go
« Reply #17 on: July 13, 2005 - 08:05:05 PM »
the carb studs are ment to hold a carb that dont take much punishment they are a less strong than a head bolt or a water pump bolt!! take a carb stud and lay it beside a water pump bolt tell me which is stronger??
« Reply #18 on: July 13, 2005 - 09:43:36 PM »
Its a good thing i don't want to use those little fellas.  I'm talking about the Actual Bolt and Holes for the "intake Manifold" ( 8 of em but i would use 4)
J.
Offline GoodysGotaCuda
« Reply #19 on: July 13, 2005 - 11:02:59 PM »
J.
Chain likes to dig into aluminum when using the intake bolts w/the intake on, otherwise i would use those holes w/o the intake on...
-Goody
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #20 on: July 14, 2005 - 02:00:41 AM »
Finally a reason worth noting, thanks Goody. :beer:
J.
dodgetkboy78
« Reply #21 on: July 16, 2005 - 11:33:50 PM »
J.
And you are pulling sideways on them, where you are pulling strait up on the accessory bolts, I have seen the threds messed up in the heads by a bent bolt from lifting it that way.
I use two, left side acessory front, right side acessory rear.
