Author Topic: Control Arm Bushings  (Read 1686 times)
Offline cudabob496
« on: August 02, 2017 - 09:42:53 PM »
On my 72 Cuda, getting some squeaking on the bushings. Should I replace both upper
and lower control arm bushings? Should I upgrade or strengthen any components?
Is there a how-to video?
Thanks
2011 Kawasaki Z1000
Re: Control Arm Bushings
« Reply #1 on: August 03, 2017 - 08:05:42 PM »
I would replace every bushing on the front end. UCA, LCA, Strut rod, and sway bar all at the same time. UCA bushings should be the MOOG offset bushings IMO. And if budget allows, ball joints and tie rods. Then get an alignment with about 3-4* positive caster and forget about your front end for a few years. :2cents:
« Reply #2 on: August 03, 2017 - 08:10:07 PM »
youtube's full of them ... This one's worth watching for sure.. https://www.youtube.com/watch?v=Nwes-SP8u4w
You have a factory service manual? http://www.mymopar.com/index.php?pid=109
Offline 73_Cuda_4_Me
« Reply #3 on: August 03, 2017 - 08:39:16 PM »
If you can swing it, get new tubular upper control arms... they can improve original design deficiencies for caster and 'bump steer'...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline Beekeeper
« Reply #4 on: August 03, 2017 - 10:37:01 PM »
I put the poly graphite bushings in my Superbee years back and really liked them. They can be a bit stiffer than original rubber though and despite the graphite in them, they still are noisier than original. I'd definitely do the entire job all at once. It's really not that bad and you'll be very happy when you're done.
Offline cudabob496
« Reply #5 on: August 05, 2017 - 07:25:19 PM »
Be tempting to buy new upper and lower control arms that already have the added strength.
Any brand recommendations?
« Last Edit: August 05, 2017 - 07:40:06 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #6 on: August 05, 2017 - 10:22:11 PM »
QA1 sells quality pieces, as do Hotchkis.
My preference would be QA1.  :2cents:
Offline 73440
« Reply #7 on: August 06, 2017 - 10:54:34 PM »
http://www.crazysmopar.com/tech_frontend_walk.html
Not an ebody rebuild but good info.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #8 on: August 21, 2017 - 01:41:50 AM »
thanks, does not look like a small job!
2011 Kawasaki Z1000
