Author Topic: Hood struts for 70 cuda  (Read 1485 times)
Offline rattlesnake
  • Rattlesnake
« on: August 03, 2017 - 12:04:30 AM »
Hey everyone, I installed a fiberglass hood on my 70. I was told by the body shop that stock steel springs would be too strong for the fiberglass hood, so I left them off. Now I need a way to hold my hood open while working or at the shows. Is there somebody that sells a small strut that can be installed on a stock hinge?
Ray,
keep honking I'm reloading
Re: Hood struts for 70 cuda
« Reply #1 on: August 03, 2017 - 07:32:15 AM »
I've seen where people use a piece of metal rod with a hook in each end. They install the piece in place of the hood spring. Obviously, it's not as nice as a strut since you have to install/remove it all the time. It's just an idea if you can't find a strut.
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #2 on: August 03, 2017 - 09:52:05 AM »
I Would use the same springs  as the T/A or AAR .  or have some re done  just my  :2cents:
Go 4 a spin Ya Why Not.
Offline drewcrane
« Reply #3 on: August 03, 2017 - 10:04:17 AM »
Yes we have a AAR hood,I went to the salvage yard found the single hood props  off of other cars modified just a bit,it low lives along the top of the radiator support I don't even think I drilled a hole one was already there , works just fine  :2thumbs:
« Reply #4 on: August 03, 2017 - 10:06:45 AM »
I Googled "AAR hood spring" and some pictures popped up.  You can see how the piece of rod works to keep the hood open.  The link will show a billet hinge with a strut on it.  The picture is from ProTouring.com.  I don't know who sells them.
http://www.pro-touring.com/attachment.php?attachmentid=49475&stc=1&d=1316802677
« Last Edit: August 03, 2017 - 10:09:12 AM by burdar »
« Reply #5 on: August 03, 2017 - 12:23:15 PM »
That picture is my car. I tried two different manufacturers of T/A hood springs and none of them worked. Either it wouldn't hold the hood up or it bowed the hood.  I now use just the stainless 3/8" rod with two bends, easy and cheap!
Offline Racer57
« Reply #6 on: August 03, 2017 - 05:20:15 PM »
Go to Ace, Home Depot, etc and buy a rod. Paint it your body color and most people will never notice it.
Offline AARuFAST
  • AARuFAST
« Reply #7 on: August 03, 2017 - 07:59:48 PM »
This is the TA spring. It is longer and narrower then the metal hood springs.
I went to ACE hardware and bought a set of turn buckles.
See pic they work great.....with the end screws you can adjust the hood opening.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline AARuFAST
  • AARuFAST
« Reply #8 on: August 04, 2017 - 10:20:41 PM »
Do you wonder where the person goes after posting a question?
 :popcorn:
1970 AAR Cuda
" I Want to Ride "
