Author Topic: single 4bbl 6 pack style air cleaner  (Read 1019 times)
Offline yamanut1970
« on: August 20, 2017 - 10:46:01 PM »
I'm starting to restore a 70 Cuda and am planning on an AAR clone. The drivetrain is a 440/4 barrel/4 speed. I know I can get an air grabber style air cleaner but what I don't know is how well it will seal on the AAR hood. With a 440, is the height going to be correct? Will a normal air grabber weather strip seal it up? I wish there was a place that had all the different air cleaners so you could go and try combinations to make sure what will work!!!
Anyone have any advice?
Offline 70chall440
Re: single 4bbl 6 pack style air cleaner
« Reply #1 on: August 20, 2017 - 11:40:58 PM »
No, it will not seal. The single 4BBL Air grabber used a rubber seal on the hood whereas the AAR and T/A air cleaner had a rubber seal on the edge. Unless you are building a high speed racer, sealing it wont net you much if you are thinking it is a performance thing. If it is just a "look" think, you will have to make your own.
Current Mopar
Past Mopars
