Author Topic: 72-74 Cuda grille installation guidance  (Read 3407 times)
« on: August 23, 2017 - 08:48:33 PM »
I need a little help in understanding where all of the "bits" of the hardware kit go. Anyone that can help, I appreciate it.
Offline 73440
Re: 72-74 Cuda grille installation guidance
« Reply #1 on: August 24, 2017 - 12:13:48 AM »
http://www.ebay.com/itm/371873869006?vectorid=229466&item=371873869006&rmvSB=true
Looks like this kit breaks it into three areas, that may help narrow it done. The seller may have and be able to send a location diagram.
I looked thru Mitchell parts manual , but no fasteners are listed.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #2 on: August 24, 2017 - 10:57:13 AM »
Ive looked through all of the reference manuals, books I have and nothing really shows location and application in detail. I can probably figure it out but Id rather know going in. It would appear that the plastic blocks are used around the headlight trim rings, however I am not sure exactly where the white round one goes.
Offline crash340
« Reply #3 on: August 25, 2017 - 09:02:21 PM »
7 are the screws that hold the headlight trim rings on, they screw into some of the metal clips number 1,
4 screw into 6 along the top of the grill into the header panel
White round blocks I'm working on for you
« Last Edit: August 25, 2017 - 09:04:49 PM by crash340 »
Greg
73 Cuda
Brisbane, Australia
« Reply #4 on: August 25, 2017 - 09:31:44 PM »
Thanks Greg. I believe that screws #3 go into the white round things and it seems to me they go in the outer lower corners but I am not positive. Screws #2 go into metal clips some place which I suspect I will figure out once I really look at it.
Offline Aracer
« Reply #5 on: August 27, 2017 - 10:34:49 PM »
I have a 74 cuda those plastic things are Mollys for the front light door, the holes that they go in are big, screws are the longest.
   The grill has flat expanding barb clips that hold the chrome trim.
The big spring nuts hold it to the header, it (grill) is a hanging facade, without bottom support.
« Reply #6 on: August 28, 2017 - 12:17:42 AM »
Thanks, I think I understand what you are saying, but I need to look at it closer.
« Reply #7 on: August 30, 2017 - 11:30:50 PM »
You don't happen to have a picture of where the "Mollys" go do you?
Offline Aracer
« Reply #8 on: September 07, 2017 - 05:17:01 PM »
I would have to take it apart.  They go in the fender structure @ the top, out side. The same as my 68.  The mollys are an extension so screw reaches the light backing structure.  They even have plastic mollys on my 1963pick up
 headlight covers. Old tech.
« Last Edit: September 07, 2017 - 06:18:23 PM by Aracer »
« Reply #9 on: September 07, 2017 - 05:56:56 PM »
Thanks. I looked and couldn't find where they went and every screw went into a J clip and I cant find any unused holes. Regardless, it is in and I am good. thanks again, perhaps one day I will see it and realize I missed something.
Offline 73440
« Reply #10 on: September 08, 2017 - 08:57:53 AM »
 I recently ordered a couple of cans of light Argent paint should arrive next week so will be taking my 73 Grill off and can look to see how that's all attached
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #11 on: September 08, 2017 - 02:11:48 PM »
I appreciate it, there appears to be a fair amount of confusion as to these "mollys" and where/how they go and are mounted.
