Author Topic: dash pad or gauges first ,rallye dash cuda  (Read 1333 times)
Offline culp71
« on: August 29, 2017 - 03:34:25 PM »
which should be put in before the other,
dash pad
gauge assemblies
Re: dash pad or gauges first ,rallye dash cuda
« Reply #1 on: August 29, 2017 - 03:37:31 PM »
Put the pad on first.
I put the pad on mine, then set the wiring harness in place, then started installing the components.  I worked on it upside down on a bench.
Offline Katfish
  • 70 Challenger
« Reply #2 on: August 29, 2017 - 05:22:49 PM »
Interesting, I've always done it in car.
Always easier to put gauges in first, no way to slide in the switch panel without lifting the dash.
Offline crash340
« Reply #3 on: August 30, 2017 - 04:46:23 AM »
Always pad first, then gauges then light switch panel, very easy to do, it's somewhat harder to install the pad nuts around the gauges if the gauges are in first. I've just swapped from a std dash to a rallye and very easy to do with the pad already in place
Greg
73 Cuda
Brisbane, Australia
Offline ksierens
    • 70 Challenger Resurrection
« Reply #4 on: August 30, 2017 - 07:55:42 AM »
And make sure to put the bezel in below the radio before installing the radio and ash try.
Kurt - SE Michigan
Offline culp71
« Reply #5 on: August 30, 2017 - 04:00:31 PM »
ok so:
pad first
then light switch assembly
then gauge assembly
bezel below radio
radio
ash tray
any other ?
Offline Rdchallenger12
« Reply #6 on: August 30, 2017 - 06:32:17 PM »
Speaking of installing all of that... where could I find replacement nuts and screws for the pad and all assemblies?
