My pan is def leaking.. nothing else.. I can see it..drip....drip.............drip.
I think part of the problem is once over tighned the pan is done... cheap metal. Also, mine is lealing where the pan is "recessed" around the two bolt holes.. WHY IS IT EVEN RECESSED??? the trans body isn't. Anyway, the reg gasket seems to always squish out a little there.. hence the leak. I then bought the plastic "hi-tek" gasket which has the 2 thin rubber seals imbedded in it.. AND the problem is that this gasket does not match up well along the same recessed areas around those two bolt holes.. HELP!!
71fish
