Author Topic: Which bell housing for a 6.4 w a TKO 600?  (Read 1271 times)
Offline daryld
« on: October 09, 2017 - 02:54:18 PM »
I purcahsed a Quiktime 6071 bell housing when I decided to do my 6.4 swap because everyone said that was the bellhousing I would need. I have a TKO 600 and not an automatic. I am now running into issue with trying to mount the mini-starter because the 6071 only seems to work with a starter mounted on the passenger side. I was told the starter had to be on the driver side because clearance issues. I have a 2016 6.4 out of a Charger which had the starter on the passenger side.
What bellhousing have those doing these swaps used when running a manual tranny? If everyone is uaing the 6071, is there something I am missing? When I flip the scatter sheild it does not seem to work.
Thank you for any advice or help you give me.
Daryl
Offline eck
Re: Which bell housing for a 6.4 w a TKO 600?
« Reply #1 on: November 01, 2017 - 03:13:13 AM »
Do you already have the tko600? How much power/tourqe is your 6.4 pushing. The tko is only rated at 600 tq and if you pump the 6.4 up you will destroy it. It also does not like to shift at high rpm.
Just food for thought.
I have a quick time bellhousing.
Hit up silver sport transmissions and see if they have one they do a bunch of tko swap bellhousings.
