Author Topic: Which bellhousing is correct for a 6.4 Hemi and TKO 600?  (Read 1201 times)
Offline daryld
« on: October 09, 2017 - 03:07:04 PM »
 When I decided to do my 6.4 swap I was told that I needed a Quiktime 6071 bell housing. I have a 2016 6.4 that had the starter on the passenger sise and a TKO 600.  The problem I am having is when I flip the scatter shield the starter does not appear to line up with the shield or bell housing and has no place to bolt on the block.  Which bell housing have those who have done this swap with a manual transmission used? Am I missing something? Can the starter be mounted on the driver side with the coreect TTI headers? I was told that the starter had to be on the driver side because of clearance issues.
 Thank you for any advice and help that you can give.
Daryl
