Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Rear seat INSTALLATION??
« previous
next »
Print
Pages: [
1
Author
Topic: Rear seat INSTALLATION?? (Read 1203 times)
69CHARGERMD
Jr. Member
on:
October 15, 2017 - 07:13:04 PM »
Last thing to do is install the rear seats on the restoration.
Dumb question,,,but which goes in first ?? The bottom portion you sit on or the back portion you lean back against?
Logged
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
shawge
Full Member
Zoiks!!
Re: Rear seat INSTALLATION??
Reply #1 on:
October 15, 2017 - 07:19:32 PM »
Back first, need to bolt it in near the bottom
Then bottom, need to push the seat loop into the hook on the floorboard
Logged
- Jerry
73_Cuda_4_Me
Jr. Member
Reply #2 on:
October 15, 2017 - 07:31:45 PM »
If you installed dynamat or other insulation, the install can be a little tougher... make sure the hooks for bottom seat bar are not twisted or bent down, which makes getting it hooked in properly difficult at best, impossible at worst...
ask me how I know...! I think someone threw a bare block in my back seat area, because driver's side hook on mine was bent down at rear by about 3/4 inch...
Logged
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
69CHARGERMD
Jr. Member
Reply #3 on:
October 15, 2017 - 07:33:39 PM »
Thanks, that's how I had tried it, need to figure out what size bolt holds the seat inside the bracket. Trying to put the bottom portion in seemed a little tight so I figured I should check before I forced it. Thanks again
Logged
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
73_Cuda_4_Me
Jr. Member
Reply #4 on:
October 15, 2017 - 07:39:20 PM »
The bottom brackets of the back seat upper portion are held by captivated washer screws that thread into the bracket mounts spotwelded to floor riser going to trunk area... seems like they were a 1/4" by 1" or 1-1/2" long below washer...
Logged
R11 V6X EN2
69CHARGERMD
Jr. Member
Reply #5 on:
October 15, 2017 - 07:53:56 PM »
Thank you for the info. Something like this
https://goo.gl/images/fYP4zP
Logged
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
73_Cuda_4_Me
Jr. Member
Reply #6 on:
October 16, 2017 - 07:26:36 PM »
A black oxide version of that, yes...
Logged
R11 V6X EN2
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
