Author Topic: car idles too high  (Read 1191 times)
Offline Belltone85
  • 1973 Dodge Challenger 360 Crate Motor, Slap Stick
car idles too high
« on: July 08, 2005 - 02:31:34 PM »
I'm not that familiar with carbs and the car idles too high what can i do to fix this?
Offline GoodysGotaCuda
Re: car idles too high
« Reply #1 on: July 08, 2005 - 03:06:21 PM »
Well there are a few different factors. but how many RPMs is it turning? Could be as simple as adjusting the screw...could be as simple as there should be a screw VERY close to the linkage on the carb (near throttle cable)...not on the main part of the carb...start turinin those w/o knowing what your are doing  :nono:. If you find that screw all it does is push the throttle at idle up, or screw it out to lower the idle...
What carb do you have?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Belltone85
« Reply #2 on: July 08, 2005 - 08:34:20 PM »
i have an edelbrock performer 750... ya i don't know what i'm doing thats why i never touched it yet..i don't have a tach so i don't know exactly what it is idling at. i let my bro drive it (stupid mistake i know) and he came back and said it was idling high and it is and i dunno what he did and he said he didn't do anything.
Offline Carlwalski
« Reply #3 on: July 09, 2005 - 03:34:26 AM »
I tech guru Chryco visits all the tech forums but you might get a better response from him and others in the Engin go fast forum.  ;) :thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Plum6Pak
« Reply #4 on: July 09, 2005 - 06:20:55 AM »
Hey NZ,  he needs the 'engine go too fast forum'   :tongue: :tongue: :tongue:
Offline KelllysCuda
« Reply #5 on: July 09, 2005 - 09:53:47 AM »
 :laughup:
Kelly
« Reply #6 on: July 10, 2005 - 08:02:48 AM »
There's a screw to adjust the idle. Backing(counter-clockwise) it off will lower idle. Another lesser possibility would be your throttle return spring isn't tight enough, or is worn.
