Author Topic: Big Block Trick Flow Heads  (Read 3509 times)
Offline cudabob496
Re: Big Block Trick Flow Heads
« Reply #15 on: November 20, 2017 - 06:47:36 PM »
Trick Flow 270s are available as well. Max Wedge ports!
https://www.summitracing.com/parts/tfs-6161t784-c01
should heads be installed with studs or bolts?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #16 on: November 26, 2017 - 10:51:32 PM »
Studs clamp better IMO, but I went with the spec bolts to make sure I could remove a cylinder head "in-frame" if ever needed. It's personal preference in this area.  :cheers:
Offline Tazinhawaii
« Reply #17 on: November 29, 2017 - 01:17:12 PM »
I did studs, but beware that any exhaust headers will need to be modified to fit with head studs.  The lower studs will hit the header flanges.  Not sure about stock exhaust manifolds, but TTi and Doug's both had to be modified (grinding the flanges).
1971 Cuda 440 six pack.  Original TX9 Black on Black.  Located in southern NH.
Offline 734406pk
  • Andy
« Reply #18 on: November 29, 2017 - 07:18:56 PM »
Good point! when using studs, the nuts stick up higher than bolts so they may interfere with headers or stock exhaust manifolds. In that case grinding for clearance will be necessary. :)
