Author Topic: Drum brake issues  (Read 756 times)
Offline rebelcuda73
Drum brake issues
« on: November 03, 2017 - 02:18:22 PM »
I have a 73 340 cuda with rear drum brakes. The drum won't come off though it mover seems as the upper shoe is against the brake drum. Tried the adjuster wheel but it won't spin. Car has been sitting for a year and hasn't moved. Any help in getting it off would be appreciated. Also any ideas on what type of rear disc set up would be good instead of drums. Already changed master with drilled slotted rotors the larger ones bought new sliding caliber set up . Thanks
Offline 73_Cuda_4_Me
Re: Drum brake issues
« Reply #1 on: November 03, 2017 - 06:04:38 PM »
Is the E-brake cable stuck?? If it doesn't release, it can really hamper self-adjuster loosening and drum removal.
You may have to use a large 3-jaw puller against axle... it will probably rip the shoes, but if you're going to be replacing anyway....
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
