Author Topic: Instrument Cluster Connections Question  (Read 1513 times)
Offline Olacmot
« on: November 26, 2017 - 02:23:39 PM »
I am tracing out some lose connections, and I have a red wire with a black connector that wasn't hooked up. My wipe/wash knob seems to have an extra post with nothing connected. Does this go here? See below picture - the post in the foreground.
Secondly, my clock has never worked. What are these lose connectors supposed to go to that I found behind the dash? (gray connector w/ red and orange wires, black connector w/ black & black/yellow wires, and yellow bullet connector) Does one hook up to the clock?
Also, it looks like someone removed the adjustment knob and and whatever connects to the adjustment part on the bottom of clock. What does the connection look like and where does the knob go on the dash?
Thanks!
Tom
Sent from my ONEPLUS A3000 using Tapatalk
'71 Challenger w/ 340
'07 SRT8 Grand Cherokee
'75 Honda CL360
Offline FY1Cuda
Re: Instrument Cluster Connections Question
« Reply #1 on: November 26, 2017 - 05:50:43 PM »
The connector with the orange and red wires powers the radio.  The empty post on the wiper switch is supposed to be empty.
Offline FY1Cuda
« Reply #2 on: November 26, 2017 - 06:25:49 PM »
I think the black connector with the black and black/tracer wires is a socket for the headlight reminder buzzer that is on a '71 but not on our '70.
Offline Olacmot
« Reply #3 on: November 26, 2017 - 10:17:28 PM »
Thank you, sir!
'75 Honda CL360
Offline JayBee
« Reply #4 on: November 27, 2017 - 08:26:59 AM »
Here's the only picture I could find of a standard dash clock with the reset ass'y. If I recall correctly, there's a shaft that goes up the black tube with a gear on the end and the chrome button screws onto the bottom of that shaft with a barrel nut.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Olacmot
« Reply #5 on: November 27, 2017 - 08:32:42 AM »
Thanks, I had no idea what I was looking for.  Where does the chrome knob/button pop out, or is it hidden behind the dash?
'75 Honda CL360
Offline JayBee
« Reply #6 on: November 27, 2017 - 11:29:27 AM »
Not hidden. There should be a hole in the plastic bezel below the clock for the knob to stick out. People have been known to remove the reset because there wasn't a hole for it if they installed a clock in a car that didn't come with it.
John
2014 Toyota Avalon
Offline JayBee
« Reply #7 on: November 27, 2017 - 11:47:20 AM »
Here's a picture of my original dash (converted it to rallye). You can see the chrome sticking out on the left below the clock. The hole has to be large enough for a bit of the black tube to stick out too.
John
2014 Toyota Avalon
Offline Olacmot
« Reply #8 on: November 27, 2017 - 02:57:40 PM »
Got it, that clears some stuff up! Thanks!
'75 Honda CL360
