If this motor had a cast crank, I would be just a wee bit leary of it being a HP block...........which should be easily identifiable, but if the steel crank got away from it, one of two things probably happened.........
1, The engine had a major probably and the crank was scarred too much to turn, or 2 its not a HP block, I suppose someone may have disassembled the engine and the crank just got away........but I would check to see if the block needs align bored and I would take a close look at the rods and main webbing in the block..........just fyi.......
