Author Topic: Paint question  (Read 964 times)
Offline MEH
Paint question
« on: January 02, 2018 - 02:01:27 PM »
Hello all, I am wanting to paint my own cuda. My question is, do I paint everything disassembled or do I have to paint jambs, then reassemble and paint the body?
Offline 70chall440
Re: Paint question
« Reply #1 on: January 02, 2018 - 06:18:11 PM »
depends on what you want the end result to be. I just painted my Cuda last summer and I painted my car assembled. It can be done either way but if you want it like the factory did it or without any flaws, generally you have to at least have the doors, hood, trunk and front and rear valances off. I had the valances off but doors and trunk lid on. I didn't have the hood on because it is an AAR hood and  painted it black. Most cars painted at a professional body shop will be painted assembled unless there is a color change and the owner is particular.
Many guys prime everything while it is disassembled, then before painting the color they will paint the door jams, under the hood, inside of the doors as well as the jam area on the doors and in the trunk. Then they assemble the car and paint the entire outside of the car. The reason here is so that any over spray (and you will have some no matter what) is body color.
Current Mopar
Past Mopars
Offline jimynick
Re: Paint question
« Reply #2 on: January 02, 2018 - 10:33:39 PM »
Yep, what the man said. If you paint it together, there is a product out there that is a round section foam that comes in a couple of different diameters and that has a sticky stripe that allows you to position it inside the open spaces between fenders and doors, hood and fenders, deck and 1/4's so that the mentioned over spray is, (if you do your job correctly) pretty much eliminated. It pulls off easily after the car is painted and the only caution is to make sure you don't overwrap any non-painted spot. Go base/clear and don't be cheap with the quality nor quantity of the clear, especially around edges and high crown areas of the body. You'll thank me for that when you get to colour sanding and buffing. Good luck  :cheers:
Offline 70chall440
Re: Paint question
« Reply #3 on: January 03, 2018 - 12:53:12 PM »
Its called soft edge masking tape and comes in different sizes. I used it when I painted my Cuda and while it does work and is helpful you have to be very detailed in positioning it so as not to get over spray past it. It has a sticky side but it isn't designed to be super sticky and can get blown off during painting. As any painter will tell you, its all about the prep.
I painted my car with single stage lime green; if I were to do it again I would go 2 stage I think.
Current Mopar
Past Mopars
