Author Topic: Dynacorn rear Assembly trunk, frame, cross member  (Read 1722 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: January 07, 2018 - 03:21:44 PM »
Hello All,
This question go out to anyone who has used the Dynacorn rear assembly piece pictured below. Every time I ask about it from an amd person or someone who uses AMD they tell me that it is made for the body they sell and doesn't fit well on a stock E body. Is this true? I know Dave sells them and I hope to make a purchase, but I want to make sure first.
Thanks,
Robert
Offline 70RAG383
  • I'm a llama!
Re: Dynacorn rear Assembly trunk, frame, cross member
« Reply #1 on: January 07, 2018 - 04:00:48 PM »
I used this piece for my restoration. it fit well and saved alot of time, labor and expense versus purchasing and welding all of the individual components (floor pans, frame rails etc. etc.).
« Reply #2 on: January 07, 2018 - 04:08:02 PM »
Awesome! I appreciate the feedback. I just removed one of the rails on my Cuda and it about killed me.
Offline jimynick
« Reply #3 on: January 07, 2018 - 10:39:05 PM »
It'll call for some careful supporting of the body since most of the normal areas will be removed. Don't forget that the complete assembly also has to be able to be gotten under and up into the car, since that may prove to be a fun thing. Obviously, measurements will be crucial, so take MANY and also take many photos of everywhere the floors tie into the rockers and firewall. It would save a bunch of fitting/welding, no doubt.  :cheers:
« Reply #4 on: January 08, 2018 - 08:07:59 AM »
Thank you very much
Offline chally_rktekt
« Reply #5 on: January 11, 2018 - 02:02:25 AM »
Does that have the rails attached already to the floor pans? I bought and test fit the dynacorn floor and under rear seat floor on my chally and both fit great. Even after replacing both rear wheel houses. I was surprised.
Bill
IG: @BBsChallengerResto
Follow the Restoration 🛠
1970 Dodge Challenger R/T SE
JS29N0B 383 Magnum 🇺🇸
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: January 11, 2018 - 12:19:22 PM »
Bill
yes these are completely welded together.
Also the fuel filler tube hole is NOT punched so it can work on Cuda. Sold plenty no issues.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
