Author Topic: cuda shaker base to hood seal direction  (Read 1285 times)
Offline culp71
« on: January 29, 2018 - 12:44:07 PM »
in which direction does the shaker seal attach to the base plate of the shaker, I see the seal has a ovals shape and a extra flap/w factory slot cut into it, does the slot go over the shaker base outer lip? with the tallest part up? or does a certain side of the seal get glued down on to the base piece, with the cut flap in a different direction?
« Last Edit: January 29, 2018 - 12:53:52 PM by culp71 »
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: cuda shaker base to hood seal direction
« Reply #1 on: January 30, 2018 - 08:15:09 AM »
Well now after reading several threads, I want to know as well.
bump for info....
Offline culp71
« Reply #2 on: January 30, 2018 - 10:54:22 AM »
here's the seal I have
Offline 1 Wild R/T
« Reply #3 on: January 30, 2018 - 11:12:43 AM »
The seal held as you are in the picture attaches to the passenger side of the base plate/adapter ring near the center & extends forward from there around the base plate/adapter ring... Where the ends join again near the center of the passenger side you cut the excess off & glue the end together then the seam is covered with black duct tape...
« Last Edit: January 30, 2018 - 11:14:58 AM by 1 Wild R/T »
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: January 31, 2018 - 11:26:22 AM »
I remember when I did mine . . . wrong . . I tried to glue it to the base then went to a show and saw one . . . got home and did it correctly.  Big difference.  Only thing that needs glued is the ends together.  Then as stated, black tape on the joint.
 :thumbsup:
« Last Edit: January 31, 2018 - 11:31:26 AM by 4Cruizn »
Offline culp71
« Reply #5 on: January 31, 2018 - 12:35:00 PM »
ok so I understand the direction of the seal, how ends are joined, and wrap direction. but does it get glued to the top outer edge of base plate, or does the base plate outer edge go inside the bottom slot of the seal?
Offline 1 Wild R/T
« Reply #6 on: January 31, 2018 - 07:47:00 PM »
In the slot.... No glue...
Offline culp71
« Reply #7 on: February 01, 2018 - 08:52:18 AM »
wonderful, thanks
