Author Topic: small block or big block  (Read 851 times)
Offline IRON MAN
« on: February 07, 2018 - 02:41:04 PM »
A neighbor a few blocks away stopped by with his 70 Challenger 340 stroked to a 416 with FItech and TKO 5spd. He check out my 73 Challenger 340. He mentioned what he did to his engine. I asked, did you ever consider installing a big block. He said, no because big blocks are too heavy and throw off the handling of the vehicle. I asked is it possible with aluminum intake/heads/headers, battery in trunk to get the same handling characteristis as a 340 Challenger? He didn't know. So I'm asking on the forum out of curiosity.
Offline 70chall440
Re: small block or big block
« Reply #1 on: February 07, 2018 - 05:17:14 PM »
If you really focused on going LW with a BB and used an aluminum block etc you could probably get to a relatively similar spot weight wise as a SB however this seems like a lot of work (and money) for not a lot of gain. That said, I guess it all depends on what you are doing or want to do. A properly build SB can and does produce quite a lot of HP. Could a BB be made more powerful, sure as there is not replacement for displacement but to what end I guess is the question. If you are trying to build a road racer with 1000 HP you might be over looking what you are trying to get as having too much power as a road racer might cause more problems than it solves. There are plenty of people making 600+ HP with a small block, so I am not sure what the attraction would be to go to a BB. Dont get me wrong, I like my 440 but I also like my 416 SB; different strokes......
Current Mopar
Past Mopars
