Author Topic: 6.4 Hemi into my 70 Challenger  (Read 2990 times)
Offline challengermaniac
« on: February 09, 2018 - 08:38:45 PM »
Hey guys,
I'm gathering information for a proposed project to swap a 2012 6.4 Hemi with it's 6 speed manual trans into my 1970 Challenger.
Just getting started with the research and looking at the Modern Muscle Xtreme Wiring Harness, although it indicates it is for a 2014 and newer Hemi if I am reading it right.
I would like to get this 2012 Hemi given it is low mileage, has the 6 speed trans, is local to me and at what I think is a good price of $8,000.
What do you think?
Thanks
« Last Edit: February 09, 2018 - 09:00:47 PM by challengermaniac »
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline moprr
Re: 6.4 Hemi into my 70 Challenger
« Reply #1 on: February 09, 2018 - 10:25:13 PM »
You would need to open up the transmission tunnel and modify the crossmember to fit the tranny in case you don't know.
« Reply #2 on: February 10, 2018 - 10:45:09 AM »
Affirmative!
While the Motor and Trans will also come with the ECU and gas pedal, I don't expect to have the key, or ignition switch or the wiring harness for it.  I understand there are after market manufactures, although some have indicated they are for the 2014 model year and newer and wanting to determine if getting a 2012 model year motor and trans is going to be problematic or not?
I'm getting some feedback that the stock six speed trans may not be a good fit without replacing the flanged rear tail shaft.
Of course there's also the matter of improving the suspension to support all of that new found horsepower.  A four link in the rear is pretty much a given, although it's the front suspension that will really involve the big bucks!
Ugh.....
« Last Edit: February 10, 2018 - 03:44:18 PM by challengermaniac »
Charlie
Edmonds, WA
Offline ragtopdodge
« Reply #3 on: February 12, 2018 - 07:19:20 PM »
I'm sure you can find other harnesses/computers that will work w/your 2012.
You may want just the engine and get the 6-speed from SST that has it's Magnum T56 configured for the shifter position in the right place.
http://www.hotrod.com/articles/mopar-overdrive-breakthrough-offset-shifter-6-speeds/
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline jimynick
« Reply #4 on: February 13, 2018 - 08:59:16 PM »
Good luck with your engine swap, but I wouldn't worry too much about the rear suspension handling the power. People have run Super Stock versions with the OEM 8.75" diff and if you really fear it, Strange makes a S60 which is their version of the hemi-spec Dana that you won't break with that engine, do what you will to it. Pre '65 Mopars used a flange final connection in the trans and you may be able to blend the flange yoke to the existing drive shaft as they did. Good luck  :cheers:
Offline 70chall440
« Reply #5 on: February 14, 2018 - 11:24:57 AM »
I hate to break it to you but "big bucks" are going to be a common theme when doing anything like this. For that matter; building any Mopar requires large infusions of $$; I am building a 73 Cuda with a stroked 340 (416) and 833 4 speed; I have kept tracks of everything I have spent on this car and I am very close to $50K. Yes they can be built for a lot less, but this is definitely not a cheap hobby.
Current Mopar
Past Mopars
