Felt a little creative today and made T/A hood hinge support rods. Drilled 5/16" holes 8-1/4" apart in flat bar stock. Used socket/button head bolts. The hood hinges have factory holes in them that are perfect for the support rods to hold the hood up. See pic. One rod is installed and one is laying on the fender. The springs were not removed while the rods were trial fitted. Using the rods eliminates the need for hood springs and worrying about the fiberglass hood bowing from the factory spring tension. I have a T/A hood which will be installed soon.
