Author Topic: 71 Challenger RT Parts  (Read 4004 times)
Offline glovemeister
« on: February 18, 2018 - 11:53:58 PM »
Entire Suspension/Drivetrain for sale from 1971 Dodge Challenger RT.
Front:
Upper Control arms
Disc Brakes-knuckles, disc, pads, dust shields,bearings, flex lines, hard lines etc.
complete sway bar-mounting brackets and everything to completely install
Torsion bars, clips, boots
Shocks (2)
Strut rods
Tie rod end
Master cylinder/Booster
Proportioning valve
Front brake lines
Rear:
Sway Bar assembly -complete
Spring pack
shackles
Drum Brakes-completed with backing plates, drums and all internals
Shocks (2)
Will include all hardware that I can get.
Price $1500 plus freight.
Some of this stuff could use a rebuild/repair/replace. Going with an aftermarket setup and have no need for it.
Also have upper cowl panel, will have vin stamp cutout and some rust damage. Good for someone that wants an original to repair. Also have a trunk floor, same condition as above. Kframe/steering gear, no discernable damage.
Steering column/wheel. Could probably use a rebuild or restore. Also have various bucket seat frames and interior panels.
1971 Challenger RT
Offline NCC1968
Re: 71 Challenger RT Parts
« Reply #1 on: October 07, 2018 - 10:52:06 PM »
Would you happen to have the K member?
« Reply #2 on: October 15, 2018 - 08:56:27 AM »
Yeah I do I will clarify that in the ad. But the front k member/front steering/steering will be pulled and shipped as a full assembly.
1971 Challenger RT
« Reply #3 on: October 25, 2018 - 08:46:13 AM »
Bump.
1971 Challenger RT
Offline Pat O'
« Reply #4 on: November 01, 2018 - 09:21:45 PM »
Still have the rear sway bar assembly?
Thanx!
