Author Topic: Cracking between quarter panel and dutchman panel  (Read 1446 times)
Offline brotow
  • There really is a Challenger in the backround
« on: February 23, 2018 - 03:02:54 PM »
Is there a good (easy) fix for preventing cracks between the quarter panel and the dutchman panel?   I noticed my 70 Challenger convertible started cracking on the drivers side, nothing on the passengers side (yet). Would welding a piece of steel under , inside the trunk across the seam, a good solution?  The car has torque boxes, sub frame connectors and front  inner fender and shock stiffener kit.  I'm just happy it's not painted yet.
« Last Edit: February 23, 2018 - 04:19:36 PM by brotow »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline 1 Wild R/T
Re: Crackinging between quarter panel and dutchman panel
« Reply #1 on: February 23, 2018 - 03:34:37 PM »
 :roflsmiley:  It was the "Easy" part that requires laughter....
 Been through this many times... Tried many fixes, sometimes on the same car, sometimes on on different cars, total of 11 cars & probably a total of 20 repairs....  Here's a few of them....
Tried welding it solid & regular filler, cracked within a few hours...
Tried welded solid & fiber reinforced (Kitty Hair) type filler, cracked within a month
Tried welded Solid & USC All Metal filler... Cracked within a month
Tried welded solid & cut a piece of 16 gauge steel to fit in the trough & welded it solid on both edges.... Then finished with regular filler.... Minor cracking after a year but better...
Tried welded solid & filled with lead, did it myself & I'm not the master of lead... Lasted a couple years but had minor cracking....
Had it leaded by an old timer who's been doing lead since the 50's.... Been that way for over 20 years & it's perfect....
Offline brotow
Re: Cracking between quarter panel and dutchman panel
« Reply #2 on: February 24, 2018 - 12:30:07 PM »
I found  extremely poor welds. Unbelievable considering the car was owned by a very famous car customizer/builder.  Added a piece of metal  underneath  and welded the cracks.  Keeping my fingers crossed.
« Last Edit: February 24, 2018 - 05:51:11 PM by brotow »
Offline 340challconvert
  • A66- Challenger Registry
    • A66CHALLENGER.COM
« Reply #3 on: February 27, 2018 - 08:04:22 PM »
You have it right: have the area leaded by someone who knows how to do it and you are done!
I have a crack in same area of my A66 vert. i am looking to do what you recommend.
1970 Challenger A66 Registry
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: March 08, 2018 - 10:49:20 AM »
This is how i did mine, "welded solid & cut a piece of 16 gauge steel to fit in the trough & welded it solid on both edges.... Then finished with regular filler" (I used all metal filler).... No cracking after five years, but I do have sub-frame connectors and torque boxes, which really help with the body flex.
