Author Topic: Turn signal light in dash  (Read 952 times)
Offline TFlynn72
« on: February 25, 2018 - 02:03:14 PM »
 How hard is it to replace the turn signal light in the dash on a 72 Cuda?
Offline 70chall440
Re: Turn signal light in dash
« Reply #1 on: February 25, 2018 - 11:22:32 PM »
Not all that hard, the bulb is in the back of the cluster, it rotates (I believe to the left) to release it, then replace the bulb and reinstall it. It grounds on the back of the cluster if I remember right, so it will not work if not replaced unless you supply a ground.
Current Mopar
Past Mopars
Offline TFlynn72
« Reply #2 on: February 26, 2018 - 10:04:34 AM »
Thanks! This is my first mopar and like to make sure before I start taking things apart. My amp gauge is not working and my headlight switch is shot I think? Always something!!!!
Offline JayBee
« Reply #3 on: February 26, 2018 - 04:13:21 PM »
I just looked at my spare harness and it appears that the socket just pushes into the cluster. Once the socket is pulled straight out you then twist the bulb out. 70chall440, I wonder if you're thinking about the light tubes on a rallye dash that rotate.
The attached picture of my spare rallye cluster shows just a hole for the turn signal bulb's socket.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline 70chall440
« Reply #4 on: February 26, 2018 - 11:48:54 PM »
JayBee - I believe you are correct.
Current Mopar
Past Mopars
