looking for some help on how a interior rear side sail panel is to be attached on a 71 cuda
from what I can tell the headliner gets pulled and stretched down to the first teeth metal strip
then the sail panel attaches over it via door panel like clip right in the middle of sail panel, however the replacement panels have no such clip attachment, rather two pieces of double sided tape and Velcro. assume this is to be put where the original clip was. also what does each edge of this panel fabric do, the top folded over the back of sail panel and glued? the bottom stretched onto lower teeth strip then front edge glue into jam, and rear pulled and attached to those teeth in the window trim channel. also does the lower edge of sail panel end up behind the lower teeth strip or over the top?
any direction as to how, they were, and should be attached, along with pics would be great.
