Author Topic: seat belt bolt lenght  (Read 1203 times)
Offline culp71
« on: April 03, 2018 - 11:02:15 AM »
new set of seat belt bolts, 2 with short shoulders the rest are longer, where do the shortest ones go?
Offline culp71
Re: seat belt bolt lenght
« Reply #1 on: April 03, 2018 - 12:18:39 PM »
I would guess the two shorty's are used for the shoulder strap that mount into headliner corner?
« Last Edit: April 03, 2018 - 03:05:19 PM by culp71 »
Offline 1 Wild R/T
« Reply #2 on: April 03, 2018 - 04:33:06 PM »
Rear seat belts outboard.., the the shoulder harness has plastic trim so it needs a little longer.... The center ones have trim & two belts...
Offline culp71
« Reply #3 on: April 04, 2018 - 10:26:45 AM »
so I put the long ones on the shoulder belts in front and they hang loose, away from the headliner, so I changed them out with the short ones, looks more correct, it pulls the assembly into the headliner slightly, but no gap and they don't hang.
another aftermarket supplied part that evidentially is not same as original. I guess ill just try every one twice with both lengths and make it work.
Offline culp71
« Reply #4 on: April 04, 2018 - 01:37:56 PM »
did any of these seat belt bolts have a spring washer or shim behind the mount tab?
Offline 1 Wild R/T
« Reply #5 on: April 04, 2018 - 04:35:41 PM »
No spring washers but a spacer between seat belts on the center bolts.... There are at least four different lengths of seat belt bolts...
Offline wegner426
« Reply #6 on: May 29, 2018 - 07:11:07 PM »
I was just wondering if you ever figured all this out, I am working on a 74 Cuda and installing the XV 3 point belts and wondering if there was ever a pictorial put together for the later cars that showed what went where?
