Author Topic: Driveshaft Ideas  (Read 2084 times)
Offline 70chall440
Driveshaft Ideas
« on: April 18, 2018 - 02:43:44 PM »
As my 73 Cuda is coming together I am getting to a point where I need to decide what to do with the driveshaft. I have the one I took off the car which is a factory one. I was given some advice not long to the effect that I should spend the money and get a new driveshaft. It probably isnt a bad idea, just not sure if I should.
That said, if I do, does anyone have any preferences as to vendors, material, etc? Or perhaps more important, what not to get. I have looked at some steel shafts (~$500) and Aluminum shafts (~$600). I am not all that worried about weight although every little bit helps. The engine will reportedly produce around 500HP and I am running a triangulated 4 link suspension. No plans to drag race the car currently but I would like to auto X it and if the opportunity arises Id like to put it on a road race track at some point.
Right now, my plan is to clean up and use the factory one but I wanted to put it out there and see what others think.
Current Mopar
Past Mopars
Offline jimynick
Re: Driveshaft Ideas
« Reply #1 on: April 18, 2018 - 11:33:58 PM »
There was a southern site on the 'net that sold used NASCAR stuff and they had big joint (no pun intended) driveshafts for cheap; like $75- 100. there seemed to be a selection of sizes and lengths and you might get lucky. Failing matching lengths, it wouldn't be too pricey to have one cut down and re-balanced. Just my  :2cents:
Offline 70chall440
« Reply #2 on: April 18, 2018 - 11:55:03 PM »
good idea, I will have to do some research.
Current Mopar
Past Mopars
Offline 7Dcuda
« Reply #3 on: April 19, 2018 - 12:30:48 PM »
I have a brand new Strange Engineering driveshaft I'm selling if you'd be interested.
Its their 3" Chrome Moly driveshaft with spicer weld ends and the big 1350 series Spicer U-Joints.  Also has a Strange Engineering heavy duty MOPAR 30 spline transmission yoke.  Its rated for up to 800 HP.
If the length will work for you Ill sell it cheap just to get rid of it.  Length is 44 3/8" center to center of U Joints.
I paid $250 for the driveshaft and $80 for the yoke for a total of $330.  Id sell it for $150 plus shipping.
Offline 70chall440
« Reply #4 on: April 19, 2018 - 01:13:24 PM »
I am interested but it might be a bit too long, according to what I am seeing, I need 43.85". What was it made for originally? I am running a A833 and a 8.75 rear.
Current Mopar
Past Mopars
Offline 7Dcuda
« Reply #5 on: April 19, 2018 - 01:42:11 PM »
70 Cuda, 440, A833 and 8.75 rear end.  I measured exactly how Strange said to.....it would fit but was just a little too close for my liking.  I ended up ordering one an inch shorter...so the measurement u need is between the two itd probably be ok
Offline 70chall440
« Reply #6 on: April 19, 2018 - 03:06:30 PM »
You may be right but thinking about this I am going to measure before I make any purchases because I have made a lot of changes to the car not the least of which is a triangulated 4 link which I suspect is going to have a direct impact on drive shaft length. I dont know when I will get a chance to measure it, but I will try and get it done sooner vice later. If you shaft works I will be in contact.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #7 on: April 19, 2018 - 03:12:30 PM »
I have an excel file with part numbers and lengths for A, B and E bodies. Not sure how to post it of even if I can but if someone needs/wants it I will need a email address unless someone can explain how to post it.
Current Mopar
Past Mopars
Offline 7Dcuda
« Reply #8 on: April 19, 2018 - 03:37:39 PM »
Fair nuff.
Offline 73440
« Reply #9 on: April 19, 2018 - 09:30:16 PM »
Looks like only photos can post , try a photo of the excel file on the screen then upload that photo.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 70chall440
« Reply #10 on: April 20, 2018 - 12:17:49 AM »
Here's the Ebody stuff
PN           Years         Dia"      Length"   Trans   Rear          Engine        Body
3578138   1974           3.00      47.40   904/230   7-1/4   318              Barracuda
2996134   1971            3.25    43.79   727/833   8-3/4   340              Barracuda
2883769   1970-71   3.25      43.85   727/833   8-3/4   340              Barracuda
2883766   1970           3.25     50.18   727           7-1/4   225 318      Barracuda
2996134   1974           3.25      43.29   727,833   7-1/4   318 360      Barracuda
2883636   1970           3.25      43.60   727           8-3/4   383 426 440 Barracuda
2883775   1970-71   3.25      42.60   727,833   9-3/4   426 440       Barracuda
2883779   1970-72   3.25      49.95   727           8-3/4   318               Challenger
2883782   1970           3.25    45.85   727/833   8-3/4   340               Challenger
3578146   1973           3.00     49.40   727/833   8-3/4   318 340       Challenger
2996146   1971-73   3.25     49.89   727/833   8-3/4   318 340       Challenger
2883656   1970-71   3.25     45.60   727/833   8-3/4   340 383 440  Challenger
2996142   1971           3.25     45.79   727           8-3/4   340 383-2       Challenger
2883667   1970-71   3.25   44.60   727/833   9-3/4   426 440       Challenger
Again, I got this off the net so I make no claims as to its accuracy
Current Mopar
Past Mopars
