what is the correct length of the arm rest insert?
as far as the arm rest goes, the smaller step section (mean to go into the opening cut into the door panel)
is over 13 1/2 inches ,the issue is the door panel entire area is not even 13 inches,
so I'm trying to figure out if the door panels are wrong or the arm rest are?
who has the variations of arm rest in white available, I have two sets both ridiculously long, I don't have any originals so I have nothing to compare it to. I was going to cut the opening in the door panel larger, but this would not help as the entire armrest is larger then the door panel arm rest area. as well as the molded cup area that notched is not located correctly either. it seems not to be just long on the front or back , but on all sides in every way just too big.
measurements of an original arm rest would be great, so I can determine if the door panels are wrong or the pad is.
