U bolts
Author Topic: U bolts  (Read 902 times)
Offline cuda_440
U bolts
« on: April 19, 2018 - 07:46:44 PM »
Does anyone know the u bolt length for xhd leaf springs on an 8 3/4 inch axle housing.
I measured the axle and perch which are around 3 1/4 inches and the springs are about 1 1/2 inches.
I see u bolts up to 9 inches and the shortest being 6  5/8.
Anyone use that xhd’s om an 8 3/4 and know their bolt length. Any info would be greatly appreciated.
Offline jimynick
Re: U bolts
« Reply #1 on: April 19, 2018 - 11:07:21 PM »
When you say "xhd" springs, what exactly do you mean? How many leaves are in your springs? I put Mopar Super Stock leaf springs under my 74 Challenger and used the original oem U-bolts. I think the right spring had 6 leaves and the lft had 5, but I'll have to check to confirm that. Not sure if that helps or not.  :cheers:
Offline cuda_440
Re: U bolts
« Reply #2 on: April 28, 2018 - 02:35:33 PM »
Thanks for reply. I got some u bolts 6 3/4 long. They could have been a half inch shorter but will work fine.
Mopar XHD leaf springs are what were used on all e bodies from the factory from what I read. I put new ones on and will see what the ride height is.
Test fit a HDK front suspension under it. Need get brakes/wheels/tires see how it sits. Then take it apart and get suspension powder coated. Paint bottom and engine compartment and put back together.  :working:
