I should probably start another topic. But I will keep posting my question in this one if it okay. Reading the install instruction on the Fitech Go street EFI 400. Here what it says :
Fuel Delivery Systems:
You may have chosen one of the
two optional Fuel Delivery System Kits from FiTech. In-
structions come with each kit. If using other fuel delivery
components you must use a 30-micron filter ahead of the
fuel inlet fitting on the Fitech throttle body.
So if I use a EFI ready tank from tank inc with their GPA-4 pump and TAN-ORG sending units like Tank inc tech told me.
I still have to put 30-micron filter in the line?
If yes what you guys use and where you mount it? Does it have to be close to the throttle body or anywhere on the line?
Also they say :
If you choose to use some other fuel delivery system
other than FiTech, it is important to make sure that you
confirm its compatibility with the FiTech EFI system. Con-
tact the FiTech technical staff to check compatibility. Fail-
ure to do so can void your warranty.
I wrote 2 e-mails telling them that I was planning on using a Tank inc system and ask them if it was okay no answer. Put the tech from Tank inc seem to know it working he the one that give me the list of all the correct parts that I needed.
Looking a those you guys think it all right?
Do I need their straps, mine are new but I dont know if they will fit?
