Author Topic: water pump, oil pump, oil pan, chain cover colors?  (Read 863 times)
Offline SwissCuda
« on: April 29, 2018 - 10:02:43 AM »
Dears,
I am rebuilding a 1970 440-6.
Even if I am using eStreet Cyl. Heads I would like to keep it as close as possible to original, factory look.
Can somebody give we suggestions on the colors for the parts in the Subject?
Would you paint the all heads of keep it raw aluminium?
Many thanks!!
R.
Offline 70chall440
Re: water pump, oil pump, oil pan, chain cover colors?
« Reply #1 on: April 29, 2018 - 01:13:11 PM »
All should be painted engine color (EV2 Hemi orange in this case)
Current Mopar
Past Mopars
« Reply #2 on: April 29, 2018 - 08:45:33 PM »
Paint the lower front of your engine timing cover area first before installing the Harmonic Balancer.
Paint the backside of  the Balancer.
Install Balancer.
Now you're ready for painting entire engine.
Roger Gibson Restorations sells the most accurate Mopar Orange. Bar None
Use VHT high temp primer.
Just light coats will be all that's necessary prior to painting.
